Discussion topic: My WiFi keeps dropping off
Message posted on 04 Dec 2025 08:53 AM
My WiFi keep dropping phone calls videos keep pausing and buffering on my phone and other devices Amazon Alexa keeps saying trying to connect to internet all things show WiFi signal but don't have a connection
I have rebooted powered hub down changed settings all off this didn't help could the hub be faulty
even sky tv sometimes says not possible to connect to the network and the hub is 3meters from the sky box all the tests says everything is good but it's not
please help sort this issue please
Message posted on 04 Dec 2025 09:41 AM
Re: My WiFi keeps dropping off
@Sean5551 The Forum is not sky Customer service when you post up, but have a try with the link below!
Try running the line test here to see if any faults are found:
