Discussion topic: My router is not working
This message was authored by: Nwarner
The fibre box on the wall has been reset and is not flashing and the router is red, this has been dropping in and out for 2 days now but today will not come back on
Re: My router is not working
@Nwarner You may wish to run the link below, see what it does for you!
Try running the line test here to see if any faults are found:
