Discussion topic: Wifi loose
This message was authored by AB131313 This message was authored by: AB131313
Wifi loose
Hi,Now for almost 2 weeks, the wifi and voice light flashing amber on my skybox, and dropping everything off wifi in the house.Need a solution asap,please.
This message was authored by PeteRG41 This message was authored by: PeteRG41
Re: Wifi loose
This is on your Sky WiFi hub, right?
Run through the steps on this page:
No connection or slow WiFi | Sky Help | Sky.com
If it doesn't work out your problem use the "I've still got a problem" button to raise a support ticket.  You might need to take a photo of your router showing the state of the lights.
____
Pete.
