Discussion topic: Wifi keeps dropping out
This message was authored by: RussellA1008
The internet light on the sky router will go red intermittently, thats when it cuts out
Then it goes green and works.
This has been happening for 3 days.
Restarting has not helped.
Re: Wifi keeps dropping out
@RussellA1008
Could you post your router statistics
Avatar for RussellA1008
Router Statistics
System Up Time: 21:47:20
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN Down 0 0 0 8223 0 00:00:00 LAN Up 1816842 756656 0 336587 39834 21:47:20 WLAN (2.4 GHz) Up 150926 0 0 2340 0 21:45:21 WLAN (5 GHz) Up 150905 0 0 2312 0 21:45:19
Broadband Link Downstream Upstream Connection Speed (Kbps) 0 0 Line Attenuation (dB) 0 0 Noise Margin (dB) 0
  • 0
