Discussion topic: Very slow gigabit broadband
This message was authored by: Jonlaw
My Internet speed is awfull since I upgraded it should be 1000gb but I'm getting at best 200gb
Re: Very slow gigabit broadband
@Jonlaw
Its 'mbps' not 'gb'. The speed you pay for is 1000mbps down the line to your router. If your only getting 200mbps on a test its very likely your using WiFi which cant be guaranteed nor would likely achieve 1000mbps. You need to use an ethernet cable to get your full speed.
I am NOT a Sky Employee
