1
This discussion topic has been answered Discussion topic: Wifi issues
This message was authored by: Sadia227
Wifi issues
My wifi does not seem to be connecting its showing 2 green and an amber light
Re: Wifi issues
@Sadia227
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you still have broadband problems after 7am use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: Wifi issues
@Sadia227
