1
This discussion topic has been answered Discussion topic: WiFi issue
This message was authored by: Jessica85
WiFi issue
It's saying we have no issue with the connection? However it's not connecting to my devices
Re: WiFi issue
@Jessica85
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you still have broadband problems in the morning use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: WiFi issue
@Jessica85
