Discussion topic: Wifi issues
This message was authored by: Pomkaila
Message posted on 30 May 2024 07:43 PM
Wifi issues
Recently had sky Internet installed. I'm connect but as soon as I leave the room the router is in, wifi calls drop out and apps say no Internet connection.
Find out more
Message posted on 31 May 2024 07:12 AM
Re: Wifi issues
@Pomkaila wifi signals lose power when passing through solid objects the denser the objectvthe more is lost so if your home has solid internal walls thst woukd explain the issue. Also anything made from metal blocks the signal so make sure the hub isn't under or behind anything with metal in it. The hub should be positioned above things like radiators. More advice on how to improve wifi here Sky Help - Slow wifi
