Discussion topic: Wifi issue
This message was authored by: Stanislas55
Wifi issue
Hi
I have been having some connectivity issues lately. Could you please have a look at it?
Re: Wifi issue
@Stanislas55
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
