Discussion topic: Fibre broadband
This message was authored by: Shaz18
Fibre broadband
Hi I've tested my hub box and it says everything looks fine but it's not working correctly and the. Second green light is off and the 4th light is amber
Re: Fibre broadband
@Shaz18
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
