Discussion topic: Wifi is terrible
This message was authored by: Jamiehawthorn
Wifi is terrible
Had sky installed Monday this week after swapping from 20 years with bt. Done the testing which says it's all ok but can't get wifi on my phone and laptops are so slow. It's really bad and I need to speak to someone
Re: Wifi is terrible
@Jamiehawthorn What speed service and also which sky hub did you go with, see the link below! What you had before BT wise would also be handy to know for the compare!
If you wish to go do it with sky then this link below may help you!
https://www.sky.com/help/home
