Discussion topic: Broadband help
This message was authored by: sweetpea77
Broadband help
My connection has been lost at least 8 times today! I have reset the box 3 times.
Re: Broadband help
@sweetpea77
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
