Discussion topic: Wifi failing
Message posted on 18 Sep 2025 01:44 PM
Wifi failing
Nio WiFi
Message posted on 18 Sep 2025 02:20 PM
Re: Wifi failing
@Julie_
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (in this case Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
