Discussion topic: Wifi dropping out
This message was authored by: LouiseHill1
Wifi dropping out
Wifi keeps dropping out
ran all diagnostic tests and done a restart but now not working at all
Re: Wifi dropping out
You've posted in the Sky Q (TV) forum?
@LouiseHill1
I have moved your thread to what seems to bethe more appropriate broadband board.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
