Discussion topic: WiFi issues
Message posted on 19 Jun 2026 06:33 PM
WiFi issues
Hello, our WiFi connection is having issues and keeps disconnecting. This is happening multiple times a day at the moment. Please can you check to see if there is anything that can be done to improve the connection. Thank you!
Message posted on 19 Jun 2026 06:37 PM
Re: WiFi issues
@Klaudia2026
You may not be aware but you haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
