Discussion topic: Faulty fibre cable
Message posted on 19 Jun 2026 05:44 PM
Faulty fibre cable
No internet - the dog has chewed the fi re cable
Message posted on 19 Jun 2026 05:49 PM
Re: Faulty fibre cable
@Ffion11 if it is the feed tomthe ONT you need to report the fault to Skywho will need to get Openreach out to fix the fault which will take a few days. However if its the cable from the ONT to the hub you can buy a repkacement from any hardware store or most supermarkets. Just look for an Ethernet cable you do not need anything fancy.
Message posted on 19 Jun 2026 06:30 PM - last edited: 19 Jun 2026 06:59 PM
Also keep an eye on the canine, because hair-fine glass is not good for the digestive system.
