12 Aug 2024 06:17 PM
12 Aug 2024 06:21 PM
Same for me! Every 5 minutes or so.
This has been happening to me for weeks intermittently. An engineer supposedly fixed the issue remotely and it was ok for a day before being back to dropping out numerous time throughout the day and the 'internet' icon on my hub turning orange or flashing orange.
Hopefully someone can help us!
12 Aug 2024 07:44 PM
Dear sky, are you listening, what can you do about it???
12 Aug 2024 08:04 PM
I've got exactly the same. Most devices (Sky Q and Q Mini, Alexa, printer) won't pick up the WiFi but all the Sky diagnostics say it's fine
12 Aug 2024 09:11 PM
Same happening here too. Very frustrating. Rang sky. They did a remote check and talk through router reset. It hasn't helped
12 Aug 2024 09:24 PM
12 Aug 2024 09:36 PM
My internet has been dropping on and off all afternoon and, like everyone else, no reports of any problems. What's going on Sky?
13 Aug 2024 07:48 AM
13 Aug 2024 08:05 AM
We have the same thing, this has been happening on and off for the last 2 weeks very frustrating 😤
Sky are you listening? 🤷🏻♀️
13 Aug 2024 08:17 AM
Interestingly I ended up disconnecting the powerline and this instantly resulted in better wifi.
Anyone else got powerlines?
Could they be causing interference?
13 Aug 2024 08:19 AM
Posted by a Superuser, not a Sky employee. Find out more@Jon_H Depends if they have Wi-Fi built in. Some don't and are just used for the function of extending the use of ethernet cables.
13 Aug 2024 09:16 AM
Mine were not wifi ones. I installed them to help provide a stable connection to the sky q box. However I suspect the knock on effect was interference with sky wifi
The manufacturer (TP) suggest updating the powerline firmware to resolve such issues.
13 Aug 2024 09:19 AM
Posted by a Superuser, not a Sky employee. Find out more@Jon_H Have TP link powerline adapters myself and never have any issue with Wi-Fi in the time I have used them.
13 Aug 2024 09:31 AM
Yes. Could well be coincidence but unplugging them resulted in immediate restoration of stable wifi. I'll try plugging them in again to see if the problem comes back!
