Discussion topic: Help
Message posted on 13 Aug 2024 01:18 PM
Help
My sky max hub is showing the white light but still unable to connect devices through WiFi it just says unable to connect
Message posted on 13 Aug 2024 01:21 PM
Re: Help
If your devices are old, they may not support wpa3. You'll have to login to your mysky.app and down grade the WiFi security settings to wpa2.
Message posted on 13 Aug 2024 01:34 PM
Re: Help
I tried this but it didn't work
Message posted on 13 Aug 2024 02:49 PM
Re: Help
Have you tried changing the password for the WiFi through the musky.app?
