Discussion topic: Wifi down
This message was authored by: Joshs
Wifi down
Please resolve urgently
Re: Wifi down
@Joshs
We are customers on here and this is a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
