Discussion topic: No broadband
Message posted on 23 Nov 2025 08:04 AM
No broadband
This is the third time this week my broadband has gone down. It has affected my exercise classes but n the peloton that I need WiFi for. And now I'm sitting here again with no internet. What is going on!!
Message posted on 23 Nov 2025 08:08 AM
Re: No broadband
@LisaG3
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
