Discussion topic: WiFi
This message was authored by: stephen+rowland
WiFi
Hello my WiFi keeps dropping off
Re: WiFi
@stephen+rowland
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
