Discussion topic: Wifi down
Message posted on 20 Aug 2025 12:50 AM
Wifi down
Tested MY WIFI CONNECTION multiple times stating everything is OK but still don't have a connection!!!🤮
Message posted on 20 Aug 2025 12:28 AM
WiFi Down
I've tested my connection and it says it's fine but I've got no WiFi it's just gone down about 10 mins ago the time now is 12-25am.
I've rebooted the modem and still no joy 😡 I am only putting a angery face because yous are saying there is full connectivity
Message posted on 20 Aug 2025 12:49 AM
Re: WiFi Down
I'm the same... don't even know what to try
Message posted on 20 Aug 2025 12:52 AM
Re: WiFi Down
Hi, I had same problem, but looks fine now
Message posted on 20 Aug 2025 12:55 AM
Re: WiFi Down
Same here. My hub says that it has no connection to the internet but Sky's online tool claims it has tested the connection and "everything looks good". I suspect the tool isn't actually testing the connection as it is claiming to do. I've tried restarting the hub.
Re: Wifi down
I'm the same ... not sure what to do
Message posted on 20 Aug 2025 01:01 AM
Re: Wifi down
I’m having the same issue. No connection at all but test says "all good"
Message posted on 20 Aug 2025 01:02 AM
Re: Wifi down
Mine as well but av got orange light so it's not got any internet connection, also saying everything is working fine😫
Message posted on 20 Aug 2025 01:03 AM
Re: Wifi down
Mines a slow flashing green light 🤦🏽♀️
Message posted on 20 Aug 2025 01:06 AM
Re: Wifi down
Message posted on 20 Aug 2025 01:10 AM
Re: WiFi Down
I've unplugged my modem and run the test and it still say full connection and everything is fine 😡
Message posted on 20 Aug 2025 01:11 AM
Re: Wifi down
Me too! Glad it's not just me. Have you all tried a hard reset?
Message posted on 20 Aug 2025 01:13 AM
Re: Wifi down
Yep, still nothing!
Re: Wifi down
What area are you please?
Message posted on 20 Aug 2025 01:14 AM
Re: Wifi down
We did, made no difference. Even tried the 'test' when the box was completely turned off and it said everything was fine! Someone telling porkies!
