Discussion topic: Internet keeps going down!
Message posted on 22 Aug 2025 03:34 PM
Internet and voice light keeps turning amber and no internet, must have happened around 5 times today.
Everytime I check my connection it says it's stable when clearly it's not.
can't contact sky aswel
Message posted on 22 Aug 2025 03:37 PM
Re: Internet keeps going down!
@Sean3019
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
