Discussion topic: Wifi constantly dropping
Message posted on 06 Jan 2026 10:54 PM
Message posted on 07 Jan 2026 05:18 AM
Re: Wifi constantly dropping
@Susans19
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
