Discussion topic: Wifi constantly down!
This message was authored by: maisey1
My wifi is constantly going down meaning the tv goes off, this happens 4-5 times a day. When I run a test check it says my wifi is all okay? This is ridiculous especially for what i pay for
Re: Wifi constantly down!
@maisey1
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
