Discussion topic: WiFi signal is poor in back rooms
Message posted on 08 May 2025 10:33 PM
Message posted on 09 May 2025 07:20 AM
Re: WiFi signal is poor in back rooms
@JigneshP Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
