Discussion topic: Wifi connectivity
Message posted on 25 Mar 2025 09:17 AM
Wifi connectivity
Wifi is not connecting to the Internet for 3 mornings in a row now. I wouldn't expect this bad level of service from sky but I will have to change provider if this continues
Message posted on 25 Mar 2025 10:23 AM
Re: Wifi connectivity
You are only telling other customers here.
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 25 Mar 2025 10:26 AM
Could you explain the issue a bit more? Do any lights on your hub show an issue? Are all devices just not able to access the internet?
