Discussion topic: Wifi connection to computer & printer
This message was authored by: Grm1
Whilst I do have wi fi in the home my computer and printer still say they are not connected  . Can you give some advice as to why this may be.
Re: Wifi connection to computer & printer
@Grm1 do you havectge white Sky Max hub? If so some okder devices can have issues connecting to these new hubs so its worth switching ghe WiFi security from WPA3-T to WPA2 to see if that helps.Also try temporarily turning off the 5GHz wifinbsnd yo see if the devices connect then All settings are in the My Sky app section for the hub.
if its a very old PC consider buying a USB WiFi adapter which cost around a £10.
