Discussion topic: Wifi connection lost
Message posted on 18 Jun 2026 11:07 AM
How long is this going to take?
Message posted on 18 Jun 2026 11:43 AM
Re: Wifi connection lost
No idea @Eoin10 You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
