Discussion topic: Issue with broadband connection
Message posted on 18 Jun 2026 11:04 AM
Hi, my sky wifi is not working.
Message posted on 18 Jun 2026 11:43 AM
Re: Issue with broadband connection
@Disha3107
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
