Discussion topic: WiFi not working
Message posted on 18 Jun 2026 11:14 AM
WiFi not working
My WiFi isn't working
Message posted on 18 Jun 2026 11:41 AM
Re: WiFi not working
@Nevhanno
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
