Discussion topic: Wifi connection issues
This message was authored by: Terri36
Message posted on 16 Dec 2025 09:56 PM
When I am in my bedroom WiFi won't connect to my phone I have to keep getting my phone restarted to connect to 5g then it takes about an hour or so to connect to wifi if it even does
i cant do this up the stairs to test it as it won't connect to my phone
Find out more
Message posted on 16 Dec 2025 09:58 PM
Re: Wifi connection issues
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
