Discussion topic: Wifi connection dropping out
This message was authored by: flyinghaggis
After doing everything possible connection is still dropping out , currently watching sky Q box showing connected then not connected,  meaning 2 mini boxes won't connect either, all tests show no issues,  router/all boxes have been switched off for 10 ,15 min and still same issues after restart,  I'm expecting this to be a router issue causing connection issues as no issues in my area
Re: Wifi connection dropping out
@flyinghaggis whst happens to the lights on your Sky hub when the connection drops? See https://www.sky.com/help/articles/hub-lights-explained-start
Avatar for flyinghaggis
All 3 lights are showing green . I watched the connection drop the reconnect on the sky q box (in settings) everything switched off overnight and still same
