Discussion topic: 1 orange light on SKy Broadband
This message was authored by: GillJH2
No Broadband Orange light on SKy brand, the orange light is the last kn the right. Have unplugged and switched off. The BT box has 3 green lights, but the left one is flashing.
Re: 1 orange light on SKy Broadband
@GillJH2 the orange light indicates that the hub has lost thecdigital voice line shich is only an issue if you use thst line if you dont and otherwise things are working you can ignore it. The green light flashing on the ONT is normal if it is labelled LAN it simply shows data is passing.
if you use the landline or your internet is affected if powering down tge hub for an hour soesnt curectge problem give Sky a call.
