8
This discussion topic has been answered Discussion topic: Wifi Stutters every 30 seconds
This message was authored by: PaulieL
Hi, has anyone come across wifi signal when on a video call where the connection stutters and freezes every minute or so? Stutter lasts for about 5 seconds each time.
This message was authored by: Highlinder Answer
Re: Wifi Stutters every 30 seconds
@PaulieL Could you please post your router stats following the link below.
Avatar for PaulieL
Avatar for PaulieL
@Highlinder - cheers! Let me know if you can see anything wrong.
@PaulieL  Are you logging into the router and switching off the Wi-Fi radios or is this doing itself? The uptime on the router is good, but the Wi-Fi frequencies only have just over an hour of uptime on them.
Avatar for PaulieL
@Highlinder - you'll have to explain that one to me! I took the stats just after I switched my work VPN off - would that make a difference. Other than that I'm not fiddling about with any settings for WIFI. Cheers Paul
Avatar for PaulieL
@Highlinder and sorry, why is there no data being transmitted or received over the 5ghz band?
@PaulieL  Does the drop happen when you are using just your Wi-Fi without the VPN or with it.   If the devices you are using can use both 2.4 and 5.0 GHz frequencies they will pick the more stable to connect to.
Avatar for PaulieL
@Highlinder The drop was happening with VPN switched off.  Is the rule of 2.4 and 5ghz as simple as connect those critical devices to 5ghz (and are nearby to the router) and then leave other devices to utilise 2.4ghz and potentially further away from the router?
