8
This discussion topic has been answered Discussion topic: Wifi Failing?
This message was authored by: Psybertron
Wifi Failing?
With no obvious change of hardware or settings overnight the WiFi from the Router won't connnect to Windows devices yet still connects fine to Android phones (Two different Windows 11 and 10 devices.) "Can't connect" from Wifi settings on the laptops.
Avatar for Psybertron
This message was authored by: Psybertron Answer
Re: Wifi Failing?
Update: Aparently some system update glitch on the Sky side.
Tech Expert "Vladimir" did a great job resetting everything ... all good.
Re: Wifi Failing?
@Psybertron
Have you tried rebooting both the Windows devices and also the broadband hub ?
Re: Wifi Failing?
Yep, all devices, including the broadband (openreach) terminal.
Re: Wifi Failing?
This message was authored by: Trina6
Re: Wifi Failing?
Do I need to ring up and speak to tech or are they working on it their end and I'm supposed to sit and wait!
Not technical at all... sorry
Re: Wifi Failing?
@Trina6
Do you want to start from the beginning and explain what your issue is ?
If it is no broadband then it could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: AmeenZahir
Re: Wifi Failing?
Hello Sky team,
My wifi is constantly failing not working properly showing no internet back forth. Can you please help me to sort it out.
Thank you
This message was authored by: Crystal3_
Re: Wifi Failing?
My Wi-Fi drops when I'm upstairs and I go to data!
Re: Wifi Failing?
@Crystal3_ Have you tried turning your mobile data off on the device when you are at home!
