Discussion topic: Wifi 6
Message posted on 11 Feb 2024 03:43 PM
Wifi 6
Hi All
Sorybif this has been asked recently ( couldn't see anything ) when are we getting a wifi 6 capable router any ideas…… or whats the alternative
Thank you
Jon
Message posted on 11 Feb 2024 03:44 PM
Re: Wifi 6
And and typing on an iPhone don't help the grammar or spelling Arggggggggghhhhhh
Message posted on 11 Feb 2024 03:46 PM
Re: Wifi 6
The sky max hub sr213 is wifi 6 but isn't available to customers with sky q mini boxes
Message posted on 11 Feb 2024 03:49 PM
Re: Wifi 6
Also it isn't compatible with g.fast ultrafast 1 connections
Message posted on 11 Feb 2024 03:54 PM
Re: Wifi 6
So as we as we don't have ultrafast, we are probably never getting this then
Whats the alternative,,,,
Thanks for the reply
Message posted on 11 Feb 2024 03:57 PM
Re: Wifi 6
What connection do you have?
It does have a vdsl modem so will work on fttc superfast connections as well as fttp just not g.fast and sky q minis
Message posted on 11 Feb 2024 05:07 PM
Re: Wifi 6
Sky Super Fast 😕
Message posted on 11 Feb 2024 05:12 PM
Re: Wifi 6
If you can get the sky max hub it would show in your my sky app -> product settings
Have you ever had sky q tv but moved to sky stream or glass
Message posted on 11 Feb 2024 05:16 PM
Re: Wifi 6
We have sky q last 5 years or so
Message posted on 13 Feb 2024 11:36 AM
Re: Wifi 6
Since you have Sky Q you wont be able to get Sky's WiFi 6 hub at this time but this may change in the future.
This does not stop you getting your own 3rd party WiFi 6 router though if thats what you'd like to have. Although I do not see the benefit of having it when you only have superfast, not ultrafast, unless you are doing lots of local LAN transfers over WiFi.
Message posted on 13 Feb 2024 11:52 AM
Re: Wifi 6
Kids and my work uses wireless vr so the extra umphhhhh would help
Cheers
Message posted on 13 Feb 2024 12:08 PM
Re: Wifi 6
Fair enough, wireless VR would be a good usecase for it.
Honestly I'd look at 3rd party solutions over Sky's offering. Its still very much a half baked product at the moment
Message posted on 13 Feb 2024 12:39 PM
Re: Wifi 6
@jamesn123 wrote:Fair enough, wireless VR would be a good usecase for it.
A WiFi 6 access point would be a more cost effective option to getting a WiFi 6 router because it's easier to set up.
I use a couple of Netgear WAX206 AP's as a wifi bridge between the Sky hub and my office upstairs, purely because it would be a PITA hardwiring, and get a fairly consistant 850 Mbps on a Sky Gigafast connection.
Message posted on 07 May 2024 12:57 PM
Re: Wifi 6
Just get a WiFi 6 access point and connect it to your sky router with gigabit cable on a gigabit port.
set the new access points SSID to something denoting it is the WiFi 6 connection and bobs your uncle.
