Discussion topic: WiFi
Message posted on 08 Dec 2025 01:16 PM
WiFi
All day my wifi has been dropping out and my app says there's nothing wrong
Message posted on 08 Dec 2025 01:39 PM
Re: WiFi
@JadeBx
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
