Discussion topic: WiFi poor signal
This message was authored by: Lalifa
Message posted on 08 Dec 2025 01:23 PM
WiFi poor signal
I have recently changed to your fibre I am still having the same problem as last year
no WiFi connection upstairs
Find out more
Message posted on 08 Dec 2025 01:38 PM
Re: WiFi poor signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link
