Discussion topic: Wifi down
Message posted on 08 Dec 2025 11:28 AM
Wifi down
My wifi is down yet all tests saying it's working! So annoying as can't get hold of anyone!
Message posted on 08 Dec 2025 01:40 PM
Re: Wifi down
@Steve634
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
