Discussion topic: WiFi
Message posted on 19 Nov 2025 10:34 AM
WiFi
Hi my wifi has been down for nearly an hour but you have texted it and say it's ok.
i work from home and can't get connected so I can't do any work.
can someone please urgently help
Message posted on 19 Nov 2025 10:56 AM
Re: WiFi
@Jax181
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
