Discussion topic: Contacting Sky
Message posted on 19 Nov 2025 10:17 AM
Contacting Sky
Does anyone have a number where you can actually speak to someone at Sky ?
Message posted on 19 Nov 2025 10:58 AM
Re: Contacting Sky
Is your broadband issue something we can help with here to save you a call?
The current methods for contacting Sky are below and depending on the reason for making contact some methods will be more appropriate than others……
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
