Discussion topic: Internet Issues
Message posted on 19 Nov 2025 10:36 AM
Internet Issues
We've been suffering from internet issues for a few days, and it's particularly bad today - cutting out fo 10-20 minutes at a time. I've tried restarting the router several times. But it's still happening!
Message posted on 19 Nov 2025 10:51 AM
Re: Internet Issues
@CraigSarge
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
