Discussion topic: WiFi
This message was authored by: Sarah54321mur
WiFi
The WiFi isn't working
Re: WiFi
@Sarah54321mur
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
▪️I AM NOT A SKY EMPLOYEE ▪️
