Discussion topic: WiFi
This message was authored by: JoaoMoniz
Message posted on 17 Sep 2025 10:43 AM
WiFi
Since I moved to Sky, I have noticed that my WiFi tends to come and go, which never happened with my previous provider. Right now it says I am connected but without Internet and the app says it all looks good. Clearly not. Any suggestions?
Find out more
Message posted on 17 Sep 2025 10:59 AM
Re: WiFi
Hi @JoaoMoniz
Do any lights on your hub change when you have issues?
I am NOT a Sky Employee
Message posted on 17 Sep 2025 11:02 AM
Re: WiFi
No, the lights stay the same. I switched off the WiFi on my device and turned it back on and it fixed the problem. I shouldn't have to do that in order to get my WiFi to work again but oh well.
Thanks for the reply
