Discussion topic: WiFi
This message was authored by: qwerk
WiFi
The test said everything is ok but I can't connect to the WiFi
Re: WiFi
@qwerk if you have the white Sky hub thst can happen if the device doesn't support the WPA3-T wifibsecurity thst unit uses by default change the wifi security level to WPA2 in the hub's section of the My Sky app.
If thst doesn't work pist again.
