Discussion topic: Sky Fibre 150.
This message was authored by: Wonkey1
Sky Fibre 150.
Everyday between 12 and 12:30 it drops out for 2 or 3 minutes, however takes everything down. Have Arlo & Blink CCTV with own connection modules, Amazon Alexa, etc etc. Everthing goes down and looses connection and needs to be reset and manually reconnected to the wifi. Sky line test says issue, then no issue.
Practically unusable.
Bright ideas
Re: Sky Fibre 150.
@Wonkey1 what happens tonthe lights on the hub when you lose connection? See https://www.sky.com/help/articles/hub-lights-explained-start.
There are no obvious things that would causeca full fibre line to drop but do you have a service over copper as those are far more prone to issues?
