Discussion topic: WiFi won’t reach two rooms
Message posted on 15 Oct 2025 08:12 PM
I've just switched to a new Sky Max Hub with a booster pod and the WiFi isn't now available in two rooms in my house. It's been a bit glitchy occasionally in the past so thought I'd be brave and try another provider after 14 years with Sky but was convinced the new hub would make a difference. I've reset, rebooted, moved the pod, try to use other boosters but no luck and after 4 days of it I'm done. Any suggestions before I cancel? Thank you.
Message posted on 15 Oct 2025 08:35 PM - last edited: 15 Oct 2025 08:36 PM
Re: WiFi won’t reach two rooms
@Pachacat1 What was your old sky hub or did you not have one as you mention another provider, so make it kind off difficult to work out, 3 pods in total for you so you may just need to apply by calling sky for more!
Other boosters of different types may just not work with the sky Max!
Message posted on 15 Oct 2025 11:22 PM
I had a Sky Q box with two boosters. It sounds like I may need to ask for extra pods then. Can't believe I never thought of that - doh! Sorry, I'm useless either technology. Thanks very much for replying
