Discussion topic: Wi-Fi not working
This message was authored by: Jack200277
Wi-Fi not working
My WiFi is not working it has been flicking on and off since 6pm and even after restarting it still does not work. My checker says it is working fine but I have no internet. Now my internet light on the hub isn't showing any colour
Re: Wi-Fi not working
@Jack200277
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
