Discussion topic: WiFi weak
This message was authored by: Corinna3
WiFi weak
Switched over to sky yesterday. I can only get WiFi in the same room at the router I need WiFi around the house not one room
Re: WiFi weak
@Corinna3 give the new hub at least 24 hours to optimise but if WiFi coverage is still poor you may need extenders which Sky can provide as part of the WiFi Max add-on see https://www.sky.com/help/articles/sky-wifi-max
Every home is different but general rule is make sure the hub is out in the open on a surface so itsxsignals are not blocked by radiators and the like.
